It seems to me that the only way to know how far you can go, after the warning comes on, is to run till you are out of gas. I've only done that in my truck (which had 2 tanks) where I could switch over. But it really messes up your fuel injectors to run to the bottom of the tank.
When I flew airplanes in 3rd world countries, we always filtered the gas through a chamois. That gives you the best chance of getting clean fuel.
The worst thing you can do is go into a gas station when you see the big truck dumping gas into the underground tanks. You're sure to get crap in the fuel even several minutes after they are done.
I like to put about 2/3 tank full and refill before the warning. I hate walking.
Removed GPS.
